My AEM TRU Boost solenoid burnt out after I paid 265 for the whole unit...So I decided for the time being, until I can get a manual boost controller, I would make my own. I used two barbed nipples, a spring, and a ball bearing. It boosts up to 19-20 psi for like a second and then calms down to 17-18 psi. When I try to turn it down just a little, max boost is only like 15 psi so I just kept it up. I was wondering if this second of 20 psi during full throttle is dangerous or could I keep it like this for the time being? Thanks
aKa Blk96SupraTT
Its not bad that it was up there for a second. I've know other guys who run like 22lbs all day on the stock turbos but then again hes looking forward to going single also. But you should really go invest the $20-$40 and get a real manual BC. But if its working for you your fine.
