Just wondering if their is a purpose to hood insulation other than sound suppression.
I've had mine off as well for as long as I can remember and never noticed any paint issues.I had mine off for years and never had paint issues. Dont remember it weighing 4 whole lbs though that seems a touch high.
Engine rocking too much from all that torque?...from the motor hitting the bare metal from the underside.
X2 what he said....It is a fire supression blanket ...
i would wrap the downpipe in exhaust tape. if not your hood will not only crack, but it will yellow where the turbo is. most cf hoods are only gel coatedI can’t really speak for the OEM hood but I know in my case with a carbon hood it was starting to burn the under side around the down pipe area on my single. The heat affected the top coat of the gloss and even had little spider cracks on the bottom side.
I run my car very hard so this might have played a factor as well. I fixed the problem by installing a sheet of thermal wrap and used high temp silicone to stick it to the bottom side of the hood.
So far so good, I haven’t noticed any more damage due to heat.![]()
Yep, already done the downpipe is wrapped aswell.i would wrap the downpipe in exhaust tape. if not your hood will not only crack, but it will yellow where the turbo is. most cf hoods are only gel coated
