1 - 20 of 47 Posts
What everyone's opinions on the hood scoops similiar to the Supra European models?
I don't like the tacked-on looks. Functionality is questionable- Autobahn-duration speeds are not widely achievable in the USA . Lastly, you permanently alter a valuable aluminum hood in the process of installing.
i like it, and it helps cool the 5th and 6th cylinders which tend to run hotter than all the others
I think it depends on what mods as well, I think it looks great stock body with a WW front lip, but dont like it so much with a totally stock car.
It's all ball bearings...
I had the euro scoop on my 94TT until my hood decided to leave the car :) I think the scoop works well with the right accompanying exterior modifications (MVP Lip/RMM Wing/Wingless). Since the search is gone, it is kind of tough to locate some good pics, but BLKLABL's car is a good example of the scoop fitting with the color & body scheme:
With the MVP lip and a black car, the scoop is sort of muted while still making the car a bit more aggressive. Here's my car with the scoop:
I obviously like it, so I'm biased, but I think it works well with the car. Not sure about the actual cooling benefits since it would only bring air in and direct it (with the correct under-the-hood parts), not let air escape at the same time. I am sure the benefits are there, just don't know if they would ever manifest themselves in real driving conditions. Hope that helps.
Chris
THE NOTORIOUS BHP
I dont like them myself but it looks fine in that pic posted.
MK4 of Them
i love it..i have a trd hood and stillen bumper right now and probably gna go to that look with stock bumper/lip/stock hood/scoop in the future
feeding your habit
I like it but I am concerned about rain in the bay - more from just having to clean it alot....
98mkiv: Mark, that why you sold me your scoop? I think if you get the full kit and don't have a strut tower bar (or modify things to make it work), rain shouldn't be an issue. Here's the full scoop diagram with the under-the-hood rain shield:
The scoop was after all a stock part from Toyota for the UK, so if it is done correctly with all the parts I can't imagine rain being a problem. Of course the other solution is...don't drive the car in the rain! That's what I do...or don't do ;)
Chris
Silent
I obviously like it said:
The air that goes in through the scoop goes out under the car or through plenty of escapable holes. The engine is not an airtight area :). If nothing else, it'd help make the air even more turbulent which would increase cooling as well.
Boost4fun
The scoop with all related accessories will lead to the snorcel on the side of the engine helping to cool the exhaust area of the twins.-So mostly cylinders 3 and 4. Since there would occure a heat problem when doing extended pulls on highways or on roadtracks. When someone is doing that with the twins I strongly recommend it. I mean Toyota put it there for a purpose on the European cars with the Autobahns.. ;)
The water inside of the engine bay is not that much. It´s only dropping on the passenger side valve cover but that´s about it..
When using a single it will not bring a big benefit IMO since the area is not that tight then and hot air can escape better.
Just my 0.02
I think it breaks the smooth look of the car. I would rather see a Viper style scoop that does not stick up from the hood. Just my 2c
Hokiesup: I don't disagree that the euro hood scoop provides some degree of cooling, I just don't know whether it is a particularly effective mod if that is your primary goal. I think if you were trying to make a real difference in under hood temperatures, venting the hood to allow hot air to escape would be the first step, perhaps in conjunction with a scoop/air inlet secondarily. That seems to be the focus of most aftermarket hoods I have seen, but what do I know?
Also, Toyota must not have considered the scoop terribly effective except in extreme circumstances as it was only offered on UK models where Autobahn-type extended high-speed runs might be in play (read: legal), and not in the US or Japan. Either way, I am sure the scoop helps a bit, plus I like how it looks :)
8valveprick: I like the euro scoop, but the Do-Luck hood was my first option and it resembles the Viper hood inlet-wise:
If it weren't on what seemed like an indefinite back order I think it would be a great alternative to the scoop.
Chris
Will work for Supra parts
I think it looks in black! No, really, I do. I was never a fan of tacked on parts, but the black Mk Ivs, posted so far, with the front lips and scoops do look good. Personally, I'd rather have a NACA duct, like the Do-Luck hood has. Even better, would the NACA duct to the passenger side of the car, sitting right above a max air intake box so the open element filter we all run would get fresh, hopefully cooler, outside air.
I love mine:)
1 - 20 of 47 Posts
