Looking for information from anyone who has experience in trying both of the following tires:
Hoosier 18153 (C07 compound) 28 x 10.0/16 Drag Slick
Hoosier 17603 28 x 11.50/16 Quick Time Pro
For context - I’m currently running the drag slick on a manual transmission full weight MKIV with bias ply skinny tires up front. On this tire, I’m able to get pretty good (repeatable) high 1.4 / low 1.5 60ft times. It’s been a great tire so I’m cautious of changing it.
I recently just looked at the QTP up close and compared the difference to the tires I have. It doesn't appear to be that much different on tread width but it looks like the QTP has a slight amount more of sidewall. Curious if that extra sidewall would help.
Also interested in any additional information regarding the compound difference between the two, the Hoosier drag tire spec sheet doesn't exactly give much info on that.
Wondering if QTP would net overall better runs on the 16inch rim setup (for manual trans) or is the drag slick the best option. And for anyone that's just run the QTP, what is the lowest 60ft you've seen on it?
Thanks.
Thanks.
