1 - 20 of 20 Posts
Hey guys, i was thinkin about gettin a new radiator and i just wanted to chek the pressure in my old on using garden hose. well after i hooked everything up and turned the water on, i had a leak in my rad, a leak in my t stat housing, and the worst one it the heater hose, right behind the head, how the hell do u change that. heres a pic maybe help understand what im talkin about
i can barely touch it with my hand :scratch:
BMM
let it cool down.. i would suggest taking off the exhasut mani. it makes it a lot easier. its not that hard.
^^ i really dont feel like taking everyhing off for a dmn hose lol, ill just go crazy with soem pliers, cuzz ill have to take the turbo, dp mani off all over again and i dont feel like it lol
90T
If it has the factory spring clips on the hose then you will need the biggest pair of needle nose pliers you can find, preferably with a 45 deg angle. Its the clip behind the head that is the pain, the one near the manifold is easy.
Discussion Starter #6
yea, im gonna let my car cool down for a sec then im gonna go out there and mess with it all day :(
the thing is i can only see the part thats near the mani, i cant tell or see where it leads off to, any one know or have a diagram so i can have an idea where the other side is at!
thnx
It just goes right above where it comes out near the mani. It's a super short hose with a 90 deg. bend. I replaced mine a couple months ago and I used some long needle nose with a bend like sp3 said.
Just make sure to put the clamps in the middle of the hose before you put it on the car.
Borrowed your image, hope you dont mind. It will be behind the valve/cam cover and the inlet will be pointing the same direction as the arrow. I suggest getting the top on first, then getting the one near the mani.
Discussion Starter #10
cool man, thnx alot for your help, i appreciate that :bigthumb:
BMM
phh, i took my whole damn head off. but i also replaced the HG :rolleyes:
Discussion Starter #12
:scratch:
thats not the point. i dont think toyota would put a coolant hose to where you have to take all the shit off to get to it, like turbo and other shit. it just makes no sense. im pretty sure i can get it now,
BMM
^ toyota didnt really think that people would be tearing into their cars. they litterally crammed everything into the engine bay. why the hell did they put the starter in such a shitty location?
anyways, good luck on replacing the hose. make sure when you put the new one on it doesnt kink.
Discussion Starter #15
ill make sure of that, thnx for your help :D
Starter removal, contact replacement, and reinstall took me around 3 hours (and it was the first time I'd ever done it). Is it different in pre-89 cars?
I didn't think replacing it was very hard at all. In fact it came off much easier then the previous 2 hoses I changed out just before it...
Would you rather have them put the starter on the bottom, where it can get hit by stuff, or on the searing hot exhaust side?
90T
You need to arrange a light up against the firewall and shining down from the top of the head.
Just be glad you are not replacing the heater hose on the intake side, its even worse!
thnx
Discussion Starter #20
thnx for your help guys, ill be tearing into it as soon as the weather gets better. MICHIGAN SUX :p
1 - 20 of 20 Posts
