1 - 15 of 15 Posts
make that blkGT4294 LOL!
A picture (or 4) is worth a few thousand words:
Manifold is Greddy, turbo is a T72. Any ideas other than a spacer elbow? Really wished everything would've bolted up. Glad I tried to test fit before I pulled the engine.
Thanks,
Nick
'91T
Back to boosting!
Go to a tangential housing.... that'll give you another inch or two...
greasemonkey
wow, funny everyone was bashing the ebay manifolds saying how superior in fitment the greddy manifold is yet it has the same issue with large turbo fitment.
My turbo DOES have an on center housing which isn't ideal. I think I'll try the tangential housing suggestion first and see how that works. Remember, the turbo frames change to a big frame around T70 IIRC. This is a pretty damned big turbo, I sort of half expected this.
-Nick
Thanks, an inch or two might just be enough. Good idea! I'll probably try that first before I try to cob up an adapter plate.
-Nick
wastegate hose is pulled
No, the ebay manifold is worse.
Anything bigger than about a 67mm compressor is going to need a spacer on a real Greddy/Trust manifold, depending on cover shape of course.
greasemonkey
-Nick
wasnt meant as an insult to you, just a general comment. and yes, thats a bigass turbo, but still requires mods to fit. all i was getting at.
Back to boosting!
Oh, and another possibly helpful tip: Get the v-band version of the tang...way easier to use...
What a/r is your oncenter?
Impeller Head
I've seen a few variations of the greddy manifold. They were sold mostly as part of a kit which came with the turbo. This one is probably for a smaller turbo because the flange is parallel to the engine. The ones for bigger turbos have an angled flange. It looks like a tangential housing will put your turbo closer to the runners, but I could be wrong. A spacer ~1-1.5 inch thick will raise the turbo but will most likely solve your problem. Good Luck!!
Discussion Starter · #12 ·
You are almost certainly right. If that [email protected] flange had a little twist toward the motor it'd be even closer. I had to take the compreesor housing off just to get to where I'm at. I'll do a spacer if I need to, prefer not to.
Thanks,
Nick
Impeller Head
Thanks,
Nick
NP. I know somebody who had the same issues and is using a spacer, it's really not that bad as far as performance goes. Still manages to make close to 700 hp at the wheels. Just make sure you make it divided too if you decide to go that route. Good Luck!
Why not just hammer in the strut tower ? aight peace :chicken:
1 - 15 of 15 Posts
