I know there are the little gears on the brakes them selves to twist to adjust. I am getting nothing out of that is there a part where you can adjust the ebrake line? or whats the best way.
^this. I have mine adjusted to where 4 clicks locks the wheels to where I can't manually spin them anymore. Once you get the hub off, just take a flathead to the star wheel.Take rear wheels off, take caliper mount and caliper off in 1 piece, take rotor off. Then you need to open up the parking brake shoes with the star wheel adjuster, like you would on a typical drum brake setup. You'll want to open the shoes up till theres a slight drag on the shoes. Dont fuck with the cable unless its broken
