Screamin LS1 SS said:
Damn, I think thats the nicest thing i've ever seen you type.
I went and tryed to take mine out and got all the screws out and messed with it for 20mins and never could get it out. WTF??!
I had some problem too. Here is how to do it:
Between the two headlights in the center is that black rubber strip. Peel it up, there is a little black tab on each end that helps keep it in place, after you undo those, it just peels out. Then unscrew the 5 tabs maybe under it. Remove that metal strip. This now allows flex in your bumper to get the lights out. Make sure you disconnected the lightwiring too. Just give it some lovin' and the lights will come out.
I also did the 9005 conversion on my lowbeams today too. Gives you 70% more light. If you want to do that as well let me know.
