1 - 12 of 12 Posts
supraman
I am installing the Greddy 60mm boost gauge with peak hold warning and need to know how to hook up a warning buzzer to it? Please help with where the buzzer wire gets hooked up? :)
supraman
No, brittany it did not come with one built in. But I want to use an external buzzer with volume control. I know some guys have hooked this up inc Steve J. I need to know what wires go where? :D
Moderator
I replied to your e-mail.
Later, Steve
2
I want to know how to do that as well. I'd actually like to use it for my EGT gauge, though.
Steve?
Supra OG
Me too! Send the instructions on or else post here. Thanks.
D u a l s t a r
I'm not sure about the Greddy gauges. But my APEXi EL gauges have a buzzer wire coming out of the wireing harness. All you have to do is hook a relay up to that wire and hook the buzzer up to the other side of the relay. (And power and ground of corse.) The relay will trigger the buzzer with out drawing too much current through the gauge.
Y
hook the poss wire of the buzzer to the yellow wire on the wiring harness of the gauge and the ground wire to ground and you should be fine
Y
Re: Re: How do I hook up the buzzer for the boost gauge?
sorry I'm backwards the yellow wire is your ground..
Moderator
The yellow wire to the ground for your buzzer and a 12 source to the positive wire on your buzzer.
Later, Steve
supraman
Discussion Starter #12
Steve, Thanks for clearing the confusion! :)
1 - 12 of 12 Posts
