Search
search dude... i'm sure this has been covered before
one hose goes to the wastegate, and the other to a part on the turbo, honestly i'm not sure, i know know that's vaugely right, i installed mine about a year an a half ago
If you take off your intake pipe, you can get a good view of your turbo. Near the bottom of the intake side, is a little gold cylinder. That's the wastegate actuator, and it has a small vacume hose going to a port on the turbo. You will basically put the boost controller in series on that vacume hose, bleeding off pressure to the actuator so the wastegate opens at a higher boost level
Here's a picture from the TSRM. The little black hose to the right of the actuator is the one you need to tap into
