1 - 4 of 4 Posts
I'm doing some wiring harness modification and I'm pulling some unused/unnecessary wiring out to help clean things up, but for the life of me I cannot get the terminals of the wire to release from the connectors for the junction box... Anyone know how to get the little green bastards in the picture below to release the wire? (I apologize for the shitty picture. Its from my phone)
they are normally held in by a small barb. you would need a very small flat screwdriver to push in and release that, then slide the wores out while the screwdriver is still in there.
SuperMember
they have a white tab ( for lack of a better word ) I think you can see it in the connector at the bottom of your picture, you can remove that with a small screw driver and it will give you access to remove them
Thanks.. I assumed it had something to do with the white tabs on the connectors. I'll go mess with it later this afternoon and see what happens :)
1 - 4 of 4 Posts
