# 4 is low.. the rest are good.. I cant remember the variance that toyota specifies is the maximum, but I think it was 15 %...
Yeah, I did a search, didnt really find anything except for other people's results, and Toyota says as long as its above 125 or something like that, then its considered good, and as long as there isnt more than a 10% variance (between the highest and lowest cylinder is less than a 10% variance.. 169-157 is appx. a 7% variance).... Leakdown test is a good idea though, thanks very much for the suggestion, Ill ask the seller if he would be willing to do that.quick said:Search. I suspect that #4 is too far out of spec. Do a leak-down test to locate the source of the problem.
Jaxx said:don't those numbers seem a little high?
