1 - 8 of 8 Posts
Volk GT-C center cap to be specific.
Are they threaded, glued, force pressed on wtf? I need to take my volk to be balanced, but can't remover the center cap :scratch:
Supralicious
I believe they are force pressed on. I have TE37s. Take the wheel off, turn it around and push it from the inside out. It should just pop out.
Hope this helps.
LEADED FUEL ONLY
They are held on by a rubber o-ring. Remove wheel and push from the rear. It'll pop right off. Be carefull you don't drop it, that soft AL will scratch when it hits concrete and those center caps are expensive to replace.
Bad Texan Boy
You could say to him put the wheel on the grass and pop the center out, so he wouldnt scratch his center cap :)
900 BHP Club :)
smack it from the back side with the plastic end of a screwdriver.
1 - 8 of 8 Posts
