1 - 10 of 10 Posts
I wanted to test start the motor before I put it in the car. It's a 2jz-gte motor btw. How do I go about starting it? Obviously have the battery hooked up, but then what next? Thanks.
LOL Not simple. Put it on a suitable engine stand, get the fuel system connected to a properly pressurized source, engine management system and relevent sensors all connected properly...
If it's a front clip, it would be easy. but if you're talking about just the engine itself, it's probably more trouble than it's worth. Just do visual checks and compression/leak down tests
much easier than one would think, and since the starter bolts to the engine, that just make it all that easier.
Here you go:
1. Engine holder is not required(but would be nice), just make sure the engine is not going to wobble around easily.
2. Get a fuel pump and something to put fuel in, then run fuel line from the pump to the engine. Inline external fuel pumps are great for this. Make sure to run a fuel return as well.
3. Get battery and hook up starter motor with trigger switch of some sort, and also run wires to the fuel pump.
4. ECU - not that hard.
There are only a few places that need power for the engine to start and run just fine.
You need power to two places on the connectors that are in the car:
IJ1(9) black/orange - power to injectors
IL1(13) black/orange - turns ECU on.
Then you need power to 2 places at the connector that is near the battery:
EA2(5 or 2-shouldn't matter which) black/red - main ECU power and sensors
EA1(4) black/yellow- this is for memory and is probably not needed to run.
Hit the starter and away you go. Oh, and make sure your igniter is grounded.
lol or you could play a little jingle like the F1 team (i think it was Honda) does when they run their motors out of the car..........at least that what i would do and make sure to get it on youtube :bigok:
Discussion Starter #10
SuperRunner, that is very generous of you.:D
The engine is on a engine stand. I'm currently being worked on. So by end of this month, i hope, i'll have it read.
1 - 10 of 10 Posts
