1 - 12 of 12 Posts
what would jesus drift?
speed cut??
like a govener?
when do you reach it??
ive done about 145 so far and still pulling.. i have 3.93's with a 4.30 speedo gear, i dont know what my real speed was.. but i never hit a speed cut..
It's only the beginning..
JDM Supras have one.
you guys are funny. DO NOT CUT ANY WIRES GOING TO THE ECU!!!!!!
Do you mean fuel cut? If so add more fuel/air and make sure you dont have boost leaks along with a way to tune it etc..
And so the journey will begin.
(if you are running stock boost and still on a stock setup you probably have a boost leak causing the problem, you need to give a little more info as to what is going on)
United States of America
Now with 0JZ
ok, maybe that wasn't the best advice, but from what I remember (on 1JZ engines atleast) the only things that need the speed signal in the ecu are the speed governer, and speed sensitive power steering. Am I wrong?
1 - 12 of 12 Posts
