Ryan P said:
Man, I've pulled on this fucking thing (the seat
) so hard, it sounds like it's going to rip apart. The tabs at the bottom came right out but the top doesn't want to come free.
I just took mine out last week. Take the bottom out first. This will give you better access to the left and right bolts on the bottom portion fo the top portion of the seat.
To take the bottom portion out, simply, grab the front of the seat and pull up. You will hear a couple of clicks. These are the snap fastners comming loose. Then pull up and out to get the rest of the bottom portion out.
The top/BackRest portion is simple. There will be a hinge on each side. Each hinge has two screws holing it in. The bottom screws can be taken out with the back rest in the upright position. The top screws can be taken out with the backrest in the folded down position.
Hope this helps.
-pete
