1 - 20 of 27 Posts
JZA70 448 rwhp everyday
Hey, my engine is fully broken in finally (1500miles) and I'm not 100% satisfied with my power results. Is it normal to not loose traction in 1st gear with out launching? With my DP i spin tire in 1stat around 3500rpm, i have stock exhaust on now and i dont. My mods are as follows 550s, lexus, hard pipes, 8psi, spec stage 3 clutch? I'm considering compression test just cuz my car doesnt feel as fast as I expected. I know i need to hit the dyno and get tuned (running kinda rich), but i gotta pass smog first.
~scott
Stock Boost SUX
So youre saying that with the DP you can break traction, but now with the shitty, restrictive, POS stock exhaust you cant? Whats the surprize? Get rid of that crap exhaust.
Plus, 8 PSI isnt that much more than stock, so youre making a lil over stock power levels. Dont expect it to be a Viper. If you want more power, crank up the boost.
I understand, and dont get me wrong I LOVE My mkiii, I'm just not quite sure exactly where i should be at performance wise. I wouldnt call burning tires in 1st without a clucth drop / slip viper performance. Just kinda paranoid about my engine build i guess. Once I pass smog, hopefully today or tomorrow, its off to the dyno to get my fuel mods tuned.
~scott
Back to boosting!
Uhh...my 8 psi right now doesn't spin in first...cause it ain't much power at all. Get real, run some real boost and then you'll wonder how you ever got them to grip. I'm staying at my 8psi right now cause I need some injectors and an intercooler, but at soon as I do.....20 psi here I come :D :D
Oh yeah, BTW vipers don't have to spool....hahahaha remember how you're power curve works... :stickpoke
Not so boring anymore
with 15 psi i would barely haze the tires in 1st on shitty pavement.. with only 235s.. It all depends on the tire/surface... I put down 289/346 too..
If i put on my stockers with 225s i would light em up through 1st and 1/2 of second
RoastBeefCurtain Commando
think about it:
1. 8psi. I know mine feels like a dawg at 8psi
2. Not tuned. If its like balls out rich that can make the difference of quite a bit of power.
3. Depending on the tires. . .. well all the rest doesnt even matter.
The 1st 2 points mean everything
25psi = 14" brakes :)
Currently, mine takes a few guys pushing it to accelerate.... LOL
Soon it will be tire shredding again however.
Check Your Face!!!
mine, well like a bat out of hell.
sorry dude i had to say it :bigok:
Hmm when I was on stock turbo running anywhere from 15-22psi, I would spin all the way through 1st and 2nd with good 245 bfg's on back....it's not as if I helped my cause by going with a way bigger turbo now...bah! damn traction
Discussion Starter · #19 ·
my problem was one of those them there code 51s!. dang there basterd was takin all my deng power away. Luckily CKanderson helped me git me dang lasso round her and hawg tie 'er real good like.
~scott
1 - 20 of 27 Posts
