I hope that wasn't directed at me. If so, my comment stands. As we all know that car has alot more than a turbo kit...
twin 76s eh, shooreohnoes:Thanks guys, I'm getting a na aerotop and placing a 1uz dry sumped with twin 76mm turbos with a turbo 6 speed box behind it.
Then to answer your first question. No, the NA rear is not going to work out for that application. You'll want to get a 6 speed rear with the 220mm setup.Thanks guys, I'm getting a na aerotop and placing a 1uz dry sumped with twin 76mm turbos with a turbo 6 speed box behind it.
That's what I was thinking. Going to be REAL laggy when not using some sort of anti-lag. I can't imagine what will go into a 1UZ build so it will stay together while under pressure from two 76's.6 speed rear has a 220mm ring gear. By the way, two 76mm turbos is a lot for a 4 liter engine.
I will be doing a full build up once i get thngs started but this is a little bit of whats going into it.
Twin 76's
2 step for boost off the line
semi grout filled block
girdle
cnc heads
billet intake plenum
90mm tb
twin 3.5" exhaust
710x305x150mm intercooler
it will be reving to 10,000rpm or a 2uz to 9,500rpm
I'm starting to think the 2uz with 4 bolt main conversion may be the go.
Cheers
Equivalent to the flow of a 107mm turbo. . . .6 speed rear has a 220mm ring gear. By the way, two 76mm turbos is a lot for a 4 liter engine.
The *early* 6-spd rear end. JDM/Asian market TT's and SZ-R's with the 6-spd had the smaller 200mm ring gear diffs after about mid '96.6 speed rear has a 220mm ring gear. By the way, two 76mm turbos is a lot for a 4 liter engine.
I'm trying to not comment negatively to what (with all due respect) just looks like a teenager with a shopping list. However I can tell you that a 4.9L 9.0:1 V8 with camshafts and manifolds suited to turbos will not make 550hp.Going to run Carrillo rods and JE pistons.
I'm going to go with the 2uz and around 4.7-4.9L of capacity.
This way i can just to the 4 bolt billet main cap conversion, girdle and semi grout fill and it should be right to rev out whilst holding some good levels of boost 25-30psi.
This engine will also be running on E85 which will help it come on boost.
The motor should make around 550 N/A with the heads and cams planned.
comp will be about 9.0 to 1.
Good info, I didn't know that.The *early* 6-spd rear end. JDM/Asian market TT's and SZ-R's with the 6-spd had the smaller 200mm ring gear diffs after about mid '96.
