1 - 1 of 1 Posts
I've been experimenting with ride height with my coilovers and found that at 1 3/4 drop (5.75" from lower control arm bolt to ground) below stock ride height, my front tire will rub the middle of the fender liner. I'm running the rears at 1 inch drop and that seems fine. Only my left front rubbed at the track, probably because there was an uphill hard right hander. I've raised the car 1/4 inch in front since the rubbing and will try it awhile. What are you other coilover guys running for ride height? I've got the HKS Hiper IIs and found I need to run the front shocks stiffer than the rears to keep the rear end from becoming overexuberant. This is with TRD swaybars front and rear. Thanks for the input, Jeff
1 - 1 of 1 Posts
