Amazing? Not sure about that from my experience..maybe...different.The balance on the MR2 is amazing.
I know MR is "Ideal" but it doesn't shine unless you're on the track, otherwise it feels more "ass" heavy (for obvious reasons) which throws me off "balance"-wise moreso than my well-balanced more-predictable FD3S.
I've owned a 91 Mr2-T, a 91 NA, and an 88 NA FWIW...perhaps the upgraded 93 suspension changes the way it feels, definitely fixes the snap-oversteer issue...perhaps that accounted for a lot of my experience.
Are you sure about that?86 NA 6 spd, hardtop no sunroof or power options....needs 4age![]()
No? Not with, ya know, the ENGINE being behind you and all...?checking in. Can't say I've ever felt that the car was ass heavy?
Nice smartass reply. What I meant is it's never been an issue with the car, like you'd feel in a 911 with the weight behind the rear axle. Sure, the weight is behind you, but it still has decent overall balance as long as you know how to drive it. My MR2 is my track car and I'm yet to have the ass end come around on me. Of course, I also run 255 tires in the rear and 225 in the front, so that helps as well.No? Not with, ya know, the ENGINE being behind you and all...?
:1poke:
plz go back to the mr2 board :wavey:86 NA 6 spd,![]()
Doesn't matter as much as you think. Remember, MR stands for mid engined, which means that the engine is in front of the rear axle, and more centrally placed.No? Not with, ya know, the ENGINE being behind you and all...?
:1poke:
The first time I understeered in the mr2, I was in shock. I was in a parking lot trying to get used to the mid engine setup, and I went into an understeer, and turned the wheel left and then right, and the front was completely unresponsive. I tried spinning the rear thinking that I would break the rear giving the front more control, but it still kept going straight, albeit faster. Again, because of the relatively little weight in the front, and the change to understeer dominant suspension in the 93+, the mr2s doesn't hold the traction in the front. Tapping the brakes before the turn in helps shift some weight to the front and solves this problem. I can't wait to take the car to a track to see what it is really about. It is confusing at times.I had a 94T and a 91T. I had more fun in the 91 because the oversteer was fun and it was a POS compared to my 94T, which is REALLY mint. Fun car to zip around in.
It is a heavy rearend car. For one, it loves to understeer, and you need to be quick with your reactions since the car isn't all that forgiving.
I was just jerkin' around...hope you took it lightly :wavey:Nice smartass reply. What I meant is it's never been an issue with the car, like you'd feel in a 911 with the weight behind the rear axle. Sure, the weight is behind you, but it still has decent overall balance as long as you know how to drive it. My MR2 is my track car and I'm yet to have the ass end come around on me. Of course, I also run 255 tires in the rear and 225 in the front, so that helps as well.
You're a tool.plz go back to the mr2 board :wavey:
