1 - 8 of 8 Posts
well wat kinda mods do you have? and i wouldnt push it past 12...
Overlooked
Stock levels. If you have to ask then you will probably break something (HG more than likely). Everyone that gets a Supra wants to crank up the boost first thing.
start at around 20psi blow a head gasket then try 19 and so on till you find the magic number, easy :)
Please dont do this.
Mk3
Discussion Starter #6
raising boost was not my first thought when i got the car. was just curious how much stock could handle.
Moderator
With the injectors and AFM the car has stock, it hits fuel cut around 13 psi. So 12 psi, compared to the stock 7 or 5 or whatever it is, is as high as you'll be seeing.
you'll blow a HG at stock boost. Get arp head bolts installed and then you can go to 12psi if it doesn't cut out.
1 - 8 of 8 Posts
