TTC Mode
HKS TI
RMM Down Pipe
Greddy BOV
Clutch/flywheel
new head gasket
redone head with stock internals.
HKS TI
RMM Down Pipe
Greddy BOV
Clutch/flywheel
new head gasket
Not enough!! Time for mo powa!!!TTC Mode
HKS TI
RMM Down Pipe
Greddy BOV
Clutch/flywheel
new head gasket
Seriously probably not much over stock, around 330whp, and that's giving you a high estimate, probably not even, your not full BPU yet, you need a BCC, a boost controller. I'd also recommend a/m intake, you can do the spring mod which will help a lot. Hope that's what you wanted
What is a BCC? sorry for newb questionNot enough!! Time for mo powa!!!
Thanks for fillin inBoost cut controller. Allows you to run more boost than about 15 psi. Without it the ECU will cut fuel and end the party.
Lol so true!you would know if you hit boost cut or not. its like hitting a brick wall during full throttle that feels as if your engine is going to just snap off and you run it over, thats a pretty accurate description.
Wow really? Man I love these cars, numbers like that and minor stuffi had basically the same mods at one point and made 352whp through the auto on a dynojet...
ive definetely never experienced that, and ive seen 17 and up to 20 psi spikes before. Guess i have one. *shrug*you would know if you hit boost cut or not. its like hitting a brick wall during full throttle that feels as if your engine is going to just snap off and you run it over, thats a pretty accurate description.
HA! I was close. Figuring he is 6 speed, he would be right around 370whp.i had basically the same mods at one point and made 352whp through the auto on a dynojet...
