1 - 4 of 4 Posts
I am going with a basic turbo kit until more money comes available. I just wanted to know if I can boost my car with the stock injectors and what the limit is with them. I am deff buying some larger injectors in the future...
Hardtopper
Are you swapping out the head gasket? If not then you will be good with a basic turbo kit @ the common 6-8psi that people run on stock compression.
headgasket will be later down the road.... I will have a map ecu for engine management and I see they have a shelf map file for the 440's....
1 - 4 of 4 Posts
