They are both going to beat you.
At least 450 RWHP...badtoy said:on a mkiv tt at?
on a mkiv tt mt?
bcc,avcr,safc,greddy fmic,dp,tanabe exhaust,vpc,egr mod,blitz
bov,walbro gss341, sard fpr set to65 psi max pressure, iridium plugs,
elektric dualfan,hks intake, max airbox, bd fuel dampener bypass
line, fluidyne radiator, water wetter
thanks
So are you saying wth the use of a FMIC, you could possibly lower the temp and run 22psi?Walser said:That much boost is not the problem; that much boost on the stock twins is. The turbos themselves are overstressed well beyond specification at 22 psi. But the engine laughs at the power output the stock twins put out at 22 psi - it's more likely the intake charge temp was consistently too high and you burned a valve or such.
