1 - 20 of 21 Posts
iSketch Master!
Ok so I got all the interior bolts out from under the dash (4 in total) I removed the master cylinder completely. There is nothing in the engine bay at all, and I see nothing else to remove. The booster wiggles a bit, barely, but it doesn't budge at all. Can someone please tell me what I am forgetting as I don't see anything else.
I checked the TSRM and I don't remember seeing anything else I needed to do with this. This is the last piece of anything left in my engine bay and I'd like to get it out! Thanks!
Alex
iSketch Master!
Discussion Starter #3 (Edited)
Why do I have to remove the brake pedal? There is nothing attaching it to the booster that would make it so solidly stuck. I removed the little pin, and slide-through bolt if that is what you are referring to, but that made no difference.
That pushrod is currently dangling, and it made no difference when I detached it.
Alex
Funny you should post this thread. I'm pulling my brake booster later today... I'll let you know how it goes..
It's not just the 4 bolts, one of them is double. You need to drop the steering column. There is a bracket that run between steering column and the dash. once you remove that you will see another screw for the booster. So here is how it goes
1: remove all four booster bolts (12mm)
2: remove the pin attaching booster to the pedal
3: remove both trays under the steering column (10mm)
4: open the front of the dash panel
5: remove 4 bolts of the steering column (14mm)
6: remove the bracket bolt (12mm)
7: remove the last bolt of the booster (12mm)
adil
iSketch Master!
looks like you have everything off then. im sure someone else will be able to help you.
Thanks!
adil
Ugh, well that is more of a PITA than I expected. Thanks for the extra info though. I might as well just pull the whole interior now too. Damn you brake booster!!! :)
It's just weird because from looking under the dash I don't see how there could be another bolt hiding. Off to the garage I go.
Alex
MONKEY TURBO FTMFW!!!!!
its a PITA to get that nut off u have to loose the bracket from the steering column i had a heck of a time, aint putting that bracket back on, only autos have them
It will never run...
Yea major pain in the ass!!! We got the 4 bolts off too, and it wasn't budging. I was asking everyone I knew. Finally...with my friend being in the same boat ( getting the bay painted ) He realized you had to drop the column, and voila! Out it came. I just let him do it for me, lol. Thinking about buying a new one now so it will look perfect.
iSketch Master!
Discussion Starter #10
Yeah it sucked. You need to remove basically everything below the steering wheel for it to even drop far enough. After I dropped everything, all under panels and the air duct, it dropped on out. It sure was a big PITA ass though.
I now have an RSP booster, and soon to be painted and cleared bay as well. Thanks for the help guys. :D If I had my camera with me I'd document it step by step.
Anyone appose me leaving that nut off for future reference? If I can just put a spacer instead of the nut it will only require removing the outer four bolts instead of all this mess.
Alex
IIRC that extra nut holds a bracket that goes to the metal bar that the dash goes to. That bar is pretty damn beefy though so I don't think its necessary, but.. Your call :)
It was easy to pull my booster out. I already have removed the HVAC unit, dash and all the reinforcements while working on removing unnecesary wiring.. lol
iSketch Master!
Discussion Starter #12
The nut I am talking about is the 4th one on the inside firewall. The last one that holds the booster on from the inside. I was going to leave the nut that holds that little reinforcement bar, and replace the one right behind it with a spacer.
And lucky you! haha
Alex
mine in 6 speed and it has one
The only reason I put the whole thing is I don't want the flex in the firewall effect the breaking. You can probably find a pic where people actually put the extra support on the master cylinder.
And lucky you! haha
Alex
Yeah that would definetly work, I was thinking for some reason you were going to leave off all of that. Reading comprehension > me.
Lucky me nothing, lol, I had to remove that much more and have to put that much more back after I'm done with cage and paint work! lol
Factory RSP Hardtopper
Alex, We both now have RSP brake boosters.:) I got my new one, ($650 :gaysex:) but it was worth it.
iSketch Master!
Discussion Starter #17
Alex, We both now have RSP brake boosters. :) I got my new one, ($650 :gaysex:) but it was worth it.
Hahaha, I always assumed the Master cylinder would be more than the booster. Damn! I think I should replace the master though. It sucks having to pick and choose which car to spend the little money I have on, haha.
Your car will prob be done before mine though!
Alex
You must be smoking crack.:lol: My car is slated to be done Juvember 32nd 2107 at the rate I'm going.:) The master from Curt is only 125 and the brake master is 80. Go figure.
iSketch Master!
Discussion Starter #19
Lol, right now it sounds more together than mine. I am stuck due to lack of funds right now though.
Alex
Me too. LOL
I have a shell, a office full of parts and and garage that won't barely close.
1 - 20 of 21 Posts
