1 - 4 of 4 Posts
I tried a search but have found limited help. Can someone please explain how to adjust an engine that is running too rich or too lean? I am planning on the Greddy EGT and possibly an Greddy air/fuel guage. My mechanic friend says that the air/fuel meter is a waste as even if it is running too rich, it can't be adjusted. Can't it be adjusted by fuel pressure? If someone has the time to run through this I would appreciate it.
Hardtopper
only way i know of is by adjusting your fuel pressure... if its running to rich it could be alot of things.. mine is probably a boost leak somewhere
Apex SAFC
If I buy one of these do I need to adjust my car on the Dyno? Can it be done driving it around?
Does getting the Apex SAFC make sense if I haenv't upgraded intercooler, injectors, and turbo yet?
I have the large bore HKS exhaust, intake, and HKS FCON, plus boost gauge and controller. Just trying to decide where to go next.Will I need a VPC?
If my assumptions are correct that it's a good idea, who sells them the cheapest?
Dan
1 - 4 of 4 Posts
