1 - 10 of 10 Posts
^do you mean like a obd scanner you will still be able to get a read out if you have aem ems system?.
my car is running lean especially on wot applications....and this is after i replaced both fuel pumps (walbro 255's) and changed the fuel filter and verified that the fpr was working correctly.
· boost life
would a obd1 reader work with a aem ems
why would you be using a stock o2 sensor with aem or are talking about the bosch sensor for the wideband
if its the bosch sensor for the wideband just screw it out the downpipe leave it plugged in get some brake cleaner spray into a rag place sensor in the folded rag turn ignition on give it a few seconds to heat up and guage should go right to 10 and stay there for a functioning sensor..
1 - 10 of 10 Posts
