·when the battery is dead and its automatic transmission . Which means the car will not start. Any kind of manual override ?
thanks
thanks
if you're talking about the shift lock, in most cars, the actual car key should fit perfectly into the hole.Alx2785 said:Yes im pretty sure it doesnt matter if you have power. If it does then there is a manual override. Its next to the shifter, and you have to take out the little plastic piece and stick a screwdriver in there. I think its a pita to get to though.
Alex
