1 - 20 of 91 Posts
Not your average auto mk3
For those of you that may want to know what is involved in the installation of BIG billet cams, here is a writeup and some pics of what you should expect to have to do to shoehorn some big cams in the 7m.
First things first, dissasemble the head completely, and i mean everything. Next, test fit these big suckers in the bare head.
Uh oh, problem #1. The lobes are big enough that they make contact with the bucket bores. Time to get out the sharpie and mark where they hit, and grind some material away so that the cams can even turn.
Now the fun part. Using an assortment od diegrinders and bits, etc, grind away material enough so that teh cams can spin fully, WITHOUT damaging the bucket bores. This takes a lot of time, trust me.
rinse and repeat x24
Now that the cams can move, its time for reinstallation of the valve/saddle/spring/retainer combo.....buuuuut not the stock ones. Here is the underbucket hardware (a MUST) in comparison to Ferrea stuff. (Ferrea on the left, TED underbucket on the right.)
Here are the underbucket shims that go, well, under the bucket. They sit in the ridge in the retainer, and are responsible for setting your lash. there aint no spittin' these puppies. (the long piece is a piece of stock that can be used to make whatever size shim you need. You get an assorment of cut ones, but a piece of stock is nice incase the ones you get are too big, as in my case)
So using the spring compressor i got from Goodson Engine Tools (expensive but worth its weight in gold) the valvetrain can be reinstalled.
Slap a shim on there.
Then slap the bucket on there.
Bolt up the cam, and check for clearance.
rinse and repeat x24 AGAIN
In this case i needed a thinner shim b/c there is not enough clearance between the lobe and the bucket. This must be checked as if it is too tight, it can hang the valves, and you'll never have compression. No good.
*NOTE* after all this fitting, the head will have to come completely back apart to be cleaned again because of the millions of metal bits from the grinding. Also, there is obviously no valve seal pictured, which will be nice to have so that my exhaust isnt blue 24/7.
Also, for those who may not know, these are the TED components 288 duration 12.5mm lift units. (pn kk611) Other cams may not interfere as much and may not require all this work, especially if it has less lift, or doesnt even need underbuckets.
Any questions, feel free to chime in, or if i forgot something, feel free to call me stupid and tell me what i forgot.
RoastBeefCurtain Commando
First thing I thought was how much material had to come off, , , then I looked at the rest of the pics.
NIce shit man. Cant wait to see that thing in action. Thats gonna be a monster.
I am assuming those are more of a one off cam right?
I love it. I want to marry it. I want to make little 7m babies with it.
Discussion Starter · #9 · (Edited)
MattOneDime said:
Nice.. do you think you will have any issues with the valve seal itself getting crushed?
I dont believe that should be an issue. Teh spring height is ~32mm installed, minus the ~13mm for the seal and bottom of the retainer, so theoretically i have ~19mm of distance from the top of the seal to the bottom of the retainer for my 12.5mm lift. I would say I would hit coil bind before i have an issue with the seal hitting.
Discussion Starter · #10 ·
Richard at TED doesnt grind these badboys until theyre paid for, so he doenst stock them, but they are part of his catalogue of cams, so they arent necessarily one-offs neither.
BMM
sticky in the FAQ section! :)
looks good.. cant wait to see it runnin!
I heart 80's Toyota's
Geez Bryan...... Those are serious!!!
BTW.... I left you a message last week, give me a call back when you are not grinding metal
Discussion Starter · #15 ·
mr touge said:
got any soundclips?
Some of those pics are from today, so nope. Trust me, there will be a post when there is though :)
Do you have comparision pics how the stock valve adjustment works? I have a hard time understanding how does the "shim under bucket" works compared to stock.
Suprasleer550 said:
^^ im with him :bowdown:
Bryan :bigthumb:
CAMSHAFT CHART
Mfg. Grind No. Lift Adv. Duration Dur. @ 0.050" Comments
TED Stock AW11 master 7.56mm 240º na OEM, early 1985/86 Toyota camshaft
TED KK101 8.9mm 262º 230º Biggest used on 20v stock camshafts; Veloci 101
TED KK102 9.70 mm 272º 232º Same as TRD rally grind. Stock ECU + injectors
TED KK103 10.35 mm 304º 254º Race. Shim-under lifters. Same as HKS
TED KK104 8.30 mm 304º 250º Same as TRD Sports Racer camshaft
TED KK104B 8.35mm 288º 240º Same as TRD Sports Racer camshaft
TED KK106 8.20mm 312º/ 264º C' sports racer camshaft
TED KK108 10.35 mm I / 10.00 mm E 264º I / 258º E 236º I / 230º E Street/Strip. OEM ECU + lifters. perfect for Turbo/SC
TED KK108B 10.70mm 262º 236º Special Turbo / SC Torque Plus; stock lifter
TED KK109 7.56 mm 256º 214º Regrind. Same as TRD cams. +10hp
TED KK110 12.45 mm I / 11.8mm E 308º/302º 264º I / 252º E Steel billet only, Race special
TED KK111 11.15 mm I / 11.10 mm E 320º I / 304º E 270º I / 260º E Race only.
TED KK112 11.50 mm I / 10.40 mm E 310º I / 304º E 264º I / 258º E High Torque, Race
TED KK113 8.65 mm 298º 250º Great street / strip racer cams
TED KK114 8.80 mm I / 8.65 mm E 272º I / 266º E 244º I / 238º E Biggest with stock ECU. Japanese race grind
TED KK115 7.70 mm 276º 224º Good power on stock engine. +20hp
TED KK116 10.4mm 292º 248º BIG torque numbers, 3000 - 8000
TED KK117 8.65mm 264º 234º Stock injector/ECU.Same as Toda
TED KK294 8.20 mm 244º 228º Great street drop-in. Same as WEB 294
TED KK329 9.75 mm 306º 264º Race only. 4000 - 9000 rpm
TED KK600 9.8mm 300º 264º NEW; std lifter WSR/Touring Race Grind
TED KK601 11.9mm 328º 278º Race
TED KK602 11.9mm/11mm 328º/ 312º 278º/266º Race
TED KK603 11.8mm 310º 270º Race
TED KK604 11mm 312º 266º Race
TED KK881 11.00 mm I / 10.70 mm E 320º/304º 278º I / 264º E Atlantic spec..#881
TED KK610 11.8mm 288º 230º Turbo / SC Race profile, shim under or shimless lifter
TED KK611 12.5mm 288º 264º Turbo/SC Race
TED KK612 8.75mm 272º 238º Stock ECU +25hp
TED KK613 11.8mm 276º 250º Turbo/SC Race
TED KK614 11mm 266º 238º Turbo/SC Race
1 - 20 of 91 Posts
