1 - 13 of 13 Posts
Holly crap.
Those are a work of art!!
goddamn...
#1 Senior browser
I've never picked up a welder, can someone explain to me how you execute nice welds in between the ports like that?
Weld the valley pan last, and then use a pencil torch around the runners. There is a bit more room than one would think.
Custom User Title
How much would that cost?
In that thread he was saying they basically start at $2500 and go up with options
BTW -- this is my favorite (I'm gathering its basically a giant fuel rail):
john marcella said:
Each seam on the fuel manifolds is 4-5 passes, because the working pressure for those two pieces are 220 psi. and needed to pass pressure testing at 300psi. I wouldn't know what to do with myself if one of these failed and a driver got burned. That's the reason for the over kill on the welding.
There are 4 root style passes to build up the fillet, then one top weld that I call a cap which is what most people call a weave.
The weave is a pattern like this l/l/l/l/l/l/l/l and drop rod in at the top and the bottom.
1 - 13 of 13 Posts
