ttmkiv said:
Anyone know how to test the TPS and the spark plug coils to see if they are in good working order? I believe mine might be causing some of my hesitation problems. Any help would be great.
Well, I hope you have better luck than me......
According to the '94 Manual, to check the coil packs:
1. remove cover
2. disconnect ignition coil connectors
3. Using an ohmmeter, measure the resistance between the (+) and (-) terminals - they should be
0.54 - 0.84 ohm (cold, or
0.68 - 0.98 ohm (hot).
"If the resistance is not as specified, replace the ignition coil".
When we tested mine, they ALL measured about 1.5 - 1.6 ohm. I dunno if it was the ohmmeter or us, but I don't think ALL the packs were bad. The measurement was OK when we checked the camshaft position sensors.
Needless to say I didn't replace the coil packs.
Are you talking about the throttle position sensor or turbo pressure sensor? I think I might need to do either/both myself.
Actually, I think I may have to get someone else (dealer?) to do it.
