Regarding the different ABS setups fitted to 9605- facelift Japanese Supras:
The same staggered 17" wheels, 4+2 piston big brakes and more complex 'Sports' ABS were available as a package on all trim levels. Standard on an RZ, but almost as common to see on a NA+auto SZ as it is on a turbo+6spd RZ-S.
I've seen many turbo cars later modified to have the larger brakes, but the brake lines in the engine bay will always be the tell.
Here's two examples from current Goo-Net Japanese dealer listings:
You can clearly see the difference with the brake lines. Although both original turbo, 6spd cars, only the white car has the higher-spec ABS system, 17" wheels and big brake option.
Here again with some NA cars:
Again, coincidentally, only the white car has the higher-spec ABS system, 17" wheels and big brakes.
...and on a heavily-optioned NA auto:
Toyota EPC drawings showing more of the difference between the standard ABS and optional 'Sports' ABS systems:
Here we can see the additional brake line running to the rear wheels, among other things. The EPC also shows this system had a larger master cylinder and different booster:
All interesting stuff.
Japanese-market Supras are certainly a mixed bag. With almost everything optional across the range and no outward badging otherwise, the trim levels in the brochure are little more than option bundles. You simply would not be able to pick the drivetrain of a Japanese Supra at a glance.
Hopefully this all works anyway. Sadly it's been a few years now since I've had to post images on a forum!
