pcv hose frt v/c-#12264-46010 [TT]
pcv hose rear v/c-#12263-46010 [TT]
t-belt tensioner-#13540-46030
supra tt throttle cable #78180-1b090
top radiator hose # 16571-46230
pcv valve-#12204-46020[TT]
pcv grommet-#90480-18001
cam seals-#90311-40020
crank seal-#90311-46001
front main seal 90311-46001
Water pump gasket 16124-46030
Valve cover gasket set 11214-46011
11213-46020
Valve stem seals 16 exhaust 16 intake 90913-02123 90913-02088
*gasket for turbo oil drain to midpan 15471-46010
*Water pump Orings 96761-24023
*2 waterpass tube orings 96761-24040
*upper waterneck to head gasket 16343-46030
*2 water lines to iac valve 16267-46011 $11.08 16281-46020
*2 water lines to throttle body 16261-46040 $10.70 16264-46030
*2 water lines to oil cooler 16283-46030 $3.65 16295-46040
*exhaust manifold to head gasket 17173-46040 17198-46010
*oil pump pickup to mid oilpan gasket 15147-AD010
11213-46020
