I'm putting together a 7mge. i sewered my gf into coming to help me work as i was assembling the head. She was putting in the lifter valves into the head and managed to force the last one in, after puttin the cams in to check the clearance, i found out that little bugger is stuck down. My question is, how to i get it to pop back out, i heated up the area a bit with a propane torch but didnt want to get crazy. theres no real room to pry it up from below. Is there any tricks anyone knows that doesnt involve me pulling the head off? If i do have to pull the head off, can i reuse the same head gasket? Both block and head were machined and cleaned so all i did was spray some brake clean and torqued it down in 3 steps.
EDIT: as a note, i have a another whole set of valves, springs, keepers, ect so damaging this one is not an issue
Any suggestions is appreciated.
Thank you
Cameron
Thank you
Cameron
