1 - 15 of 15 Posts
TOO broke MK3
hey iwas taking apart this 87 turbo with auto today i notice that theres 2 extra hose in the radiator... i try to traced where the lines go and it seems that it goes into the auto tranne...
anyways i was thinking of putting this radiator in my 5 speed turbo... but should i use it as an oil cooler?(or will it be to hot) or should i use it for power steering cooler?
or should i just stick with the other radiator that i have?
Senior Member
You already have an oil cooler, I would plumb it up as a power steering cooler. That or just drain and plug it.
TOO broke MK3
yeah i know but isnt the cooler in the radiator bigger? or mayby im thinkg of putting/ using both for oil cooler...
cooler oil=high presure right?
I was kind of wondering about doing this also. The OEM replacement rad that I bought has the tranny cooler in it, but I did a 5 spd swap so I don't need it. I thought it would be neat to get rid of the stupid stock PS "cooler" and plumb it into the tranny cooler.
I didn't know if it would actually cool it at all though since it's part of the radiator.
TOO broke MK3
yeah... but it worries me because the possibility that the oil might heat up the temp of water OR visa versa
yea i have the auto radiator, too and was considering using it for an oil cooler. any of u 5spd swap guys done this? Pros?,Cons?
Captain Hammer
I would not use it for a oil cooler, if it cracks, you've got water mixing with your oil, and you'll be buying a engine... unless you like to do that.... but using it as a PS cooler, THANK YOU! Im doing that tommrow.....
TOO broke MK3
Discussion Starter #10
um but what happens if theres a crack and the ps mix with the water? wont it have almost similar effect?
i really dont want to take that kind of risk...
knowing my supra somethings bound to break when you least expect it...
PS fluid and auto tranny fluid are virtually the same.....
Dr. Jeff Lange
Heh, yup, our cars use auto tranny fluid for PS.
Captain Hammer
Well, a powersteering system is like $1500 cheaper then a motor... so pick your risk
1 - 15 of 15 Posts
