Hello. I have a 93.5 single 6-speed, and have mounted a Hurst roll/control today. I have removed the TRAC pump etc so the installation was pretty easy. BUT it does not work, and I am sure that everything is mounted correctly.
Anyone know if the ABS system has something to do with it ?
THANKS in advance,,
Best regards
PS Motor AS
Boost Junkie
Which directions did you use? If you used the Titan directions you need to swap the brake lines going to the linelock.
Steve
