I get this hydraulic sound when I start up my car, not matter cold or warm, I can hear it in the car, and it will disappear (suddenly) in about 20 to 30 seconds, does anyone have this problem? (if it is one), what's causing it?
what is it? how do I check?kdirty130 said:check the hydraulic blinker fluid level.
If you pop your hood and look at the top of the headlight housing between the radiator support and the plastic lens of the light there is a little bubble floating inside a level marker tube on the head lights at the top. If the bubble is in the middle of the lines or passes the little line towards the back of the car it's OK. But if the bubble passes the mark toward the front you need some blinker fluid.atmsel said:what is it? how do I check?
YOU DA MAN!!!! Excellent description. :bowdown:SupraTico said:If you pop your hood and look at the top of the headlight housing between the radiator support and the plastic lens of the light there is a little bubble floating inside a level marker tube on the head lights at the top. If the bubble is in the middle of the lines or passes the little line towards the back of the car it's OK. But if the bubble passes the mark toward the front you need some blinker fluid.
==== tube==== | line | O (bubble) | line | ====tube====
