Elvis, to modify the arist fan all i did was center the aristo fan on the 7m Radiator, you can see that some of the mounting points actually fit.
Then you will have to take a dreml to the shroud so it will be accepted and held in place on the bottom of the 7M radiator. after that just mark the rear of the shroud and use a band saw to cut the shroud. after that I used angle aluminum and some rivets to get the shroud enclosed.
so basically you will need the following tools/materials
marker
band-saw (or any saw)
dremel
file ( to clean the melted plastic after dremel)
drill
angled aluminum
rivets
rivet gun
took me ~ 1.5 hrs to finish the shroud
then you will need to get the cooler from the aristo clip and mount it to the fron part
of the car, for me it was a bit easier since im using a bracket i made when I put my FMIC
on.
here is said bracket with the aristo hydro fan cooler...
*you will also have to bend the aluminum pipes a bit for the cooler,
Its a lot of work, truthfully i would have gone electric fans at this point with all the
other stuff that is holding up my build.
and if I cant get an ecu or find a way to control this the hydro setup will cost me in time once again.
p.s. I am using my old oil cooler for the powersteering pump cooler now, all that has been plumbed and fit so that is all good to go.... just need to finish wiring *dreading it almost lol and turbo setup a/c and misc other odds and ends.
-ian
