1 - 7 of 7 Posts
Hey Guys,
2JZGTE,
I've installed a Hypertune Intake Manifold and Throttle Body, but the throttle pulley is touching the power steering pump. Have you guys whom has installed this manifold, seen this already? If so, what was the solution?
Thanks for your assistance.
TntSupra
Check your install, I have the same setup and mine fit perfectly with about a 1/4" to spare.
B_Wise324
Thanks for the reply. The oil line fitting on the pump, is that the stock fitting or was it modified in any way?
TntSupra
Rotate the throttle body to where the pulley is on top, that's how mine is and I know that's how Twins Turbo installs all their Hypertunes as well. I was also able to fit a NA reservoir on the TT pump and save the hassle of finding a new spot for the TT power steering pump reservoir.
I also rotated my throttle body.
1 - 7 of 7 Posts
