1 - 12 of 12 Posts
Well i ran the diagnostics thing on my super moniter and it showed a code 52 (knock sensor signal) i have no idea what it is and i can't find it in the manual i have, any info would be good!!!! i hope it's nothing to serious!!!
Discussion Starter · #2 ·
Turbo or not? First make sure they are plugged in and not shorted out. If you find they are fix it, clear your codes. Then drive it to see if the code returns. There are other potential factors that could lead to the code: ignition (plugs and or timing), gas, boost.
i used the search here and nothing came up, but yeah i'll check the turbo connections and everything, thanks for the help!!
or someone could just tell him.. might be easier..
your engine ran lean... it had too much air and not enough fuel. Its potentially an engine killing situation. The 'knock sensor' is basically a microphone attached to the engine which listens for explosions caused by the above. when detected, the ECU alters the ignition to prevent your engine from going bang.
You could have a boost problem, or a fuel problem.
see... it wasnt that hard was it?
*BLacK SuPrA GTE* said:
Well explained HedgehogSandwich, it is more easier when people explain the solution to a problem rather than explaining the search button....
Not if the topic has been covered 5 thousand times and could be easily accessed using the SEARCH button.
Basic forum rules where ever forum you go.
Originally posted by 94silver
The purpose of this forum is to allow new users to ask questions or talk about their cars, the club, the board, or any other related topic while becoming acclimated to the environment.
You, as an experienced member, will have the opportunity to answer questions for the new members, greet them, etc. You WILL NOT, however, flame them or act in a condescending manner towards them.
When you get the urge to flame one of the new members, or tell them to search for their answer, you must do one of the two following things:
1. Do a search related to their question, read the results, and copy, rephrase, or link to the answer in your reply.
2. Do not reply.
The new members are here to learn, just as you are, so be respectful.
If you witness this behavior, please PM me with a link to the thread and the appropriate actions will be taken.
Now that the unpleasant stuff is out of the way, have fun!
-Jimmy
Exactly as drjonez did.
http://www.supracentral.com/oldschool/htm/knock.htm
PS -- please, please take more than 15 minutes to do a search. Chances are very good most of the problems that you will com across in the next few months will have been covered many times before. See the thread "forum rules and search hints" at the top of this section for some hints on using the search
1 - 12 of 12 Posts
