1 - 7 of 7 Posts
What is the best link that describes how to fix a BHG. I need pictures, muchos pictures. I really don't know much about cars, the only things i can do are change tires, oil, and disc brake pads.
Destroyer of Turbos
yum...id say do a search.. there are a few out there that have a pretty indepth guide on how to fix it. make sure u do alot of research..the more the better
boost freak
eHoss said:
...I really don't know much about cars, the only things i can do are change tires, oil, and disc brake pads.
if that's the case, then you really shouldn't be attempting a BHG fix. either find someone knowledgeable who can help you or do it for you, or have a professional do it.
Have you guys seen the new McDonalds ad for the nuggets....."Now made with white meat" WTF was in it before then!!!!!!!!!! Now there used to be dark meat and white meat pieces but wth was it if they're making it with white meat now!!!!!!!!
Although I tend to agree with drjonez, if you must, goto
http://www.cygnusx1.net/supra/library/TSRM/index.html
You can also pickup a Haynes or Chilton manual from an autoparts store, or have a bookstore order it for you. Now, most of the time either of them is worthless, but there were *basically* 2 types of supras....NA and turbo. So they aren't that bad, plus they are a little more detailed about little stuff you should be doing.
1 - 7 of 7 Posts
