1 - 9 of 9 Posts
Retro Stuntin'
I'm told I need to buy the following:
valve stem seals
2 hoses for valve covers
valve cover gaskets
2 front cam seals
I have a 1995 Supra Auto TT
thank you,
tko
Super Moderator
11213-46020 RH V/C GASKET LIST 14.27 COST 10.90
11214-46011 LH V/C GASKET LIST 14.27 COST 10.90
90210-07001 V/C BOLT WASHERS LIST 2.26 COST 1.73 EA X 16
90311-40020 CAM SEALS LIST 7.12 COST 5.44 EA X 2
90913-02088 EXHAUST SEALS LIST 4.89 COST 3.73 EA X 12
90913-02090 INTAKE SEALS LIST 4.89 COST 3.73 EA X 12
exhaust, silver in color, 9.68 mm high, = 90913-02088
intake, brownish in color, 10.36 mm high = 90913-02090
OPTIONAL:
12262-46020 RH PVC HOSE LIST 9.87 COST 7.53
12263-46010 CENTER PVC HOSE LIST 8.95 COST 6.83
12264-46010 CENTER PVC HOSE LIST 8.95 COST 6.83
12204-46020 VALVE PCV LIST 5.22 COST 3.99
12261-46031 LH PCV HOSE LIST 7.71 COST 5.88
90480-18001 PVC GROMMET LIST 4.60 COST 3.52
90105-06166 BOLT, V/C LIST 0.71 COST 0.55 EA X 12
90980-11246 Coil Pack Connector List 6.32 Cost 4.83 ea x 6
82998-12440 Repair Terminal List 5.69 Cost 4.34 ea x 12
KEEPER REMOVER TOOL:
www.ketool.com
1.805.786.0911
http://www.mkiv.com/techarticles/valve_stem/index.html
Retro Stuntin'
Thank you for the quick reply Curt. Someone will be doing the work on my car. So which parts in the list do I need? Just the stuff above the optional list? Can you explain the optional list?
Retro Stuntin'
Thank you Curt. Oh I forgot one more thing. I need to change my timing belt. What parts do I need? Just the belt?
Retro Stuntin'
Discussion Starter #6
Did a search in your Tech Corner.
I need these?
13568-49036 TIMING BELT LIST 30.56 COST 22.23 X 1
90311-46001 CRANK SEAL LIST 10.57 COST 7.70 X 1
Super Moderator
Usually You Do The Belt At 60 And 120k , Pump At 120k.
13568-49036 Belt, Timing List 33.56 Cost 25.62
90311-46001 Seal, Fm List 13.83 Cost 10.57
90311-40020 Seal, Cam List 7.12 Cost 5.44 Ea X 2
13505-46041 Idler Sub List 83.94 Cost 64.08
13540-46030 Tensioner List 71.39 Cost 54.51
16100-49846 Pump Assy List 161.73 Cost 123.48
16343-46030 Gasket, List 3.60 Cost 2.76
96761-24023 Ring, O List 2.83 Cost 2.16 Ea X 2
16325-62010 Gasket, List 5.32 Cost 4.06
Retro Stuntin'
Discussion Starter #8
oh damn way more stuff...LOL...yea the belt was last done at 60K...I'm at 150K..so umm I think I'm overdue...haha
1 - 9 of 9 Posts
