1 - 11 of 11 Posts
Cali guys: i need a stock midpipe with working cat
hey guys, it is smog time here in california. I need your help. My cat is blown and i can't pass smog without it. Does anyone here have one i could borrow, or buy. Or maybe you might know where i could look to find one. 1995 california NA supra.
Discussion Starter #2 (Edited)
i just got a quote on the midpipe and cat for my car and the price was soo much!. I know someone here has changed their cat . any suggestions of where to make things less costly.
would it be possible to just change the piping and use a universal cat. If so, would i drill a hole for the sensor.( i say this, because the sensor uses a flange instead of being a screw in sensor)
I would post in the California or even Northern California forum... I'm sure someone has one in his garage.
I'd let you borrow mine but mine is busted as well (ran turbo through a stock cat).
You can go to any local muffler shop and have them cut off the cat you have, and install a new one for under $150 including labor.
Then run 2quarts of denatured alchohol to 2-3gallons of gas in the tank and try smogging.
You should pass with ease.
~Alan
1 - 11 of 11 Posts
