All of my gauge lights along with all the parking lights are not working. I checked all the fuses and all are ok. I do not know what the problem is. Can someone give me some advice on what I should do? Help me
all the fuse's ? under the dash and under the hood ?
I'm Jeff Kiang Bitch!
If you've tapped into any wires in the dash harness to connect gauges, any electronics, etc. you may want to see if any wires are exposed and are grounding out. This same exact thing happened to me and I found that an exposed wire was the problem. Always try to use shrink wrap instead of tape if you can.
Electrical tape can come undone and can cause minor irritating problems like this. Good Luck!!
