1 - 11 of 11 Posts
Well I need some parts, I have pictures to aid in the advice part.
First of all I need an oil pan for a 2JZ-GTE I beleive it is a three peice ordeal oil pan upper w/ turbo, oil pan lower, and a baffel plate? Below is a picture of my current oil pan, from an aristo I believe are there any other parts that I am going to need to work with the new oil pan?
Second is parts for the transmission, this comes in two steps.
I need all the parts for the shifter assembly, where is what I have . . .
Then i need the parts for engagin and disengaging the clutch, I suppose this will include the slave cylinder along with a release fork maybe the release bearing, what is the difference between the RELEASE BEARING, Supra, w/Turbo, Bearing and the RELEASE BEARING, Supra, w/Turbo, Hub? and any other parts that you could think of that would help me get this engine into my car.
Ah yes, I was checking that thread out last night. I just woke up, but I am more of a visual person, nad the numbers from MKIV.com do not appear to match with Toyota part numbers:(. I get to the clutch hydraulics part, and I am not sure what I need or do not need as I am not completely aware of the way the system works. Basically I need to know if I need the Master cylinder. My car is already manual, an 89 N/A. If you could help me that part it would be great.
Clutch Hydraulics:
31470-14060 slave cylinder list 64.61 cost 47.77
90080-10055 bolt list .89 cost .65 x 2
31410-14310 master cylinder list 99.39 cost 73.49
90179-08237 nut list .91 cost .68 x 2
31481-14260 tube list 20.52 cost 15.24
96816-50335 hose list 24.86 cost 18.47
31484-24010 bracket list 6.69 cost 4.97
31482-14060 tube list 10.89 cost 8.06
90119-06406 bolt list .69 cost .50
96991-10080 clip list 1.20 cost .89 x 2
90119-06733 bolt list .54 cost .41
90080-11231 bolt list .51 cost .38
90461-08702 clamp
79191-00502 Castrol GTX brake fluid pt. list 3.75 cost 2.50
Shifter parts:
33504-14130 shift knob list 103.63 cost 76.63
33511-14031 control shaft list 25.15 cost 18.60
33513-22030 yoke list 7.63 cost 5.65
33530-14442 93.5-95 short throw shifter list 126.44 cost 93.49
90301-11015 o ring list 2.92 cost 2.15 x 4
33531-14010 boot list 39.44 cost 29.16
90387-08134 collar list 1.91 cost 1.41 x 2
33555-14110 boot list 31.55 cost 23.33
33555-14100 boot list 9.83 cost 7.27
33556-14050 seat list 1.54 cost 1.14
33057-14010 bracket list 44.33 cost 32.78
33570-14070 shifter tri-pod list 96.77 cost 71.56
93381-16016 bolt list .85 cost .55 x 4
90179-08095 nut list 1.14 cost .85 x 2
90105-08200 bolt list .89 cost .65 x 2
91651-60835 bolt list .26 cost .20 x 4
90105-08076 bolt list .74 cost .55
90179-08233 nut list .91 cost .68
90250-06026 pin list 1.06 cost .79
90467-21010 clip list 2.61 cost 1.93
33546-22020 bushing list 14.15 cost 10.47 ea x 2
You can use the B & M shifter in place of the stock one.
Clutch parts:
90363-12002-77 pilot bearing list 8.76 cost 6.48
96152-00500 snap ring list 2.66 cost 1.97
90903-63001 t/o bearing list 65.50 cost 48.44
90560-50001 snap ring
90560-79001 spacer list 2.31 cost 1.71
90206-12006 wave washer list 1.57 cost 1.17
90520-75001 snap ring list 2.97 cost 2.20
31264-14060 spring list 2.97 cost 2.20
31231-14050 hub list 33.38 cost 24.69
31204-14060 fork list 65.16 cost 48.18
31234-14020 spring list 1.97 cost 1.46
31236-14030 support list 31.27 cost 23.12
90119-08079 clutch cover bolts list .46 cost .33 ea x 6
90119-10054 bolt list .86 cost .64 x 2
90910-02115 flywheel bolts list 9.72 cost 7.18 ea 8
13450-0W011 flywheel list 611.96 cost 452.53
Use your own supplied clutch cover and disc.
This will get you started The cluch hydraulics you'll have to modify to fit in a MKIII.
Discussion Starter · #10 · (Edited)
The phone call thing was suppose to be humor, I understand it would be a pain in the ass, I also understand that it probably happens quite frequently and there is no room for humor. To top all of that off, I suck at internet humor.
I sent a reply e-mail there were a few minor things, but I am sure you can figure them out.
Thanks again.
[edit] I am quite frankly amazed that all of those parts are in stock you guys rock.
1 - 11 of 11 Posts
