1 - 15 of 15 Posts
· got boost???
on a highway drive, i smell a lot of unburnt fuel? most after i hit boost and then you can really smell it...but if cruising itsn ot as bad but can still smell it....car has a full 3 inch turbo back w/ test pipe....would tuning the car make the car run better ? also what could be causing this ?
· HKS T51R
tuning the car will make it run better and add some hp. but maybe not as much as, if you had more mods. your car shouldnt need tuning with those mods, its proabably your o2 sensor thats gone, or your afm needs adjusting. have you checked your timing or anythin?
· got boost???
timing is good.....o2 sensor could possible be bad.....not sure what it could be....
· got boost???
hmm would it bad that bad? i kno a w/o a cat it would smell more but i smell a strong fume of unburnt fuell....
If you think its rich, throw it on a dyno or get a wideband :) Most supras DO run on the rich side... I had to take ALOT of fuel out even on stock fuel pressure and stock 440cc injectors after getting my wideband to get it fairly lean during boost (11-11.5 afr)
· 2005 LP640
I can't wait to get my tuning done by Intense Motorsports :)
Finally driving my car after 5 months, now a small break-in and then it's off to the dyno.
My car feels so damn slow right now........all the power is 4K-6.25K :(
· got boost???
yea...i'm thinking i might have to lean it out a bit....but i'll be getting a MAFT, walbro, and injectors soon so i'll probablydo it later...
· Premium Member
I wouldn't go their if i where you! they will fuck your supra up! remember that kid with the fucked up mkiv where do you think he got all his stiff done at?
But you don't half to listen to me but learn bye experience they always say is the best way.
· Escaped from infinite lag
widebands are so cheap these day for the cost of one tuning session at a shop you can buy one and do it yourself. why would you ever pay someone to do somthing you can do yourself
· got boost???
Discussion Starter · #13 ·
what kind of wideband are u guys using? i havne't seen some real cheap ones
· 2005 LP640
Guess I'll be making the trip down to tucson for WOTM then for tuning :(
I had forgotten about Intense.
1 - 15 of 15 Posts
