1 - 18 of 18 Posts
Mr. Brightside
impossible in a TT, get an NA
got twins?
Do a quick search....HotSoup, John H and I are consistent drag racers...HotSoup has gone 10.9 (no NOS), John H is an 11.22 and I run 11.55s.
Drag radials, good burnout, higher octane, FMIC, more boost, TTC mode...that will get you on the way.
Diehard 4G63/AWD User
Correct me if I'm wrong but all you guys (& girl ;) ) are autos, while he's getting a 6-speed. That may make a little difference but it has been done. :)
Its easier with an automatic, but I ran a number of 11.6 passes at
with my old 6-speed at straight BPU. You will need drag radials more
than likely though.
Wayne
If you guys took the time to simply read one of the stickys above "Updated top 10 1/4 mile times for Stock Twin" it clearly shows the top 10 even for 6sp's which are all in the mid to low 11's.
And my old car went 11.30, TT 6 sp 95 went 11.22, and Drift TT23 went 11.19, all w/ 6 sp's. BTW, congrats on TX2K6 :)
Alex D said:
Wrong.......... There have been quite a few that have run 11's in a BPU car.
Thanks captain obvious. Probably didn't notice the guy was kidding around did you?
I went 11.34 with hks ev easy, g force 94 ecu,vpc,cam gears,17" bfg drag radails,full weight with 6pt cage.
Went 11.10 with the same stuff and a 50 shot.
Tripp
my 6spd has the basics and runs 11.7 consistently. Full turbo -back exhaust, you can use a BC if you like or just pull the wastegate line ( don't forget your boost-cut controller or fuel cut defenser), a FMIC, BFG drag radials, 100 octane gas and reset the ecu . trapping 120 with 1.87 60ft's. With the drag radials you should be able to go lower in the 60ft's making your E.T. lower.
Fineline Performance
Discussion Starter #17
"my 6spd has the basics and runs 11.7 consistently. Full turbo -back exhaust, you can use a BC if you like or just pull the wastegate line ( don't forget your boost-cut controller or fuel cut defenser), a FMIC, BFG drag radials, 100 octane gas and reset the ecu . trapping 120 with 1.87 60ft's. With the drag radials you should be able to go lower in the 60ft's making your E.T. lower."
Thats what Im talking about!!! Thank you! I hope it will work out for me! One more thing do I need to get any type of suspension set up?
Marc
Thanks guys!
1 - 18 of 18 Posts
