1 - 2 of 2 Posts
Was having an issue with my vvti solenoid and now that we got that fixed, my IAT sensor is not registering in my emu black. Car is an aristo swap with tweakd harness. I had a local shop do the wiring (not the tuner) and will be picking it up shortly. Does anybody have any pictures on how this should be wired so i can go over everything?
its only 2 wires, ground and signal, the ground should or might be brown?
if you have a used/old one, the ceramic sensor inside might be bad,
also if the wiring was for a usdm , which has the air temp signal in with the MAF wiring, maybe they didn't correctly split the 5 wires?
the sensor gets 5v i think, not 12 v , same as the tps sensor , take off the IAT pig tail and look on the inside make sure the pins are all secure and not pushed out or damaged, then continue with checking if the wiring is correct, like L is ground , R is signal or vise versa...
1 - 2 of 2 Posts
