I'm going to have my front stock MKIV rims widened to 17x11 and move them to the rear and run the 17x9.5 in the front.
Assuming the 12.7mm of offset for ever 1" added to the rim( 3" total) my front(now the rear) wheel will have a offset of +88.1. So to get back to the 50mm offset a 1.5" spacer(38.1mm) will need to be installed on the rear.
That all being said is a 50mm offset "ideal" for a 17x11 with a 315/35/17 tire? I've looked around and have seen everthing from needing more like +52mm or less +48mm.
TIA
TIA
