And I guess since I've already raised the white flag, anybody know where this tube goes?
Sent from my SM-G781U1 using Tapatalk
As you probably already know, there's a valve and rubber gasket that goes between the IACV and intake manifold so not sure how that will fit even if the tube is removed. I would just look for another replacement that matches your old one.So my Supra won't idle and dies and I was told it was the idle air control valve. The one I picked up looks different than the one I had in it though... The one I had in it has the tube the one that I picked up as a replacement does not. Can I use this one without the tube or does the tube move? I can't really see how to get the tube off any suggestions? View attachment 289479
That goes to the vsv (on the thermostat housing) which also connects to carbon canister sucking gas tank vapors.And I guess since I've already raised the white flag, anybody know where this tube goes?
